RFM
Everything posted by RFM
  1. Thormann, the top of the treath part of the M12 nut is oval, not round, as a safety Item.
  2. If there is no large leak, the amount of oil you have put into the engine will be too little. Pour 1/4 can at a time until the max. on the dipstick is reached. Probably the tick in the engine come through too little oil in the engine (valve train), a completely empty engine after disassembly/reassembly will have to contain more oil.
  3. As you yourself notice, the car must be locked, only in this condition most can bus connections are interrupted after a few minutes, only alarm remains active.
  4. Sway bars are mounted on the sub chassis, front and rear, on the one hand and on the struts on the other, they have no influence on the adjustments.
  5. Sway bars do not influence the wheel alignment, you can easily replace them.
  6. The release function is indeed effected by the gas strut, this happens regularly, replacing the strut is the solution.
  7. These parts are mounted on the left and right side, under the clamshell, with the aim to protect the convertible top from friction through to the hingesmechanism when the top is down.
  8. This is the dryer element of the airconditioning, the cooling water radiator is placed last of the package of radiators and has no filling cap.
  9. It seems that the collector, where the brushes run on, is completely worn out. Just replace the brushes will not have much effect.
  10. You will need a PIWIS or similar diagnostic tool to reset the code, airbag codes and other safety items, can't reset manually.
  11. If the car is equipped with a Tiptronic gearbox, check the vacuum operated cooling watervalve to the Tiptronic heat exchanger. The membrane wants to leak vacuum after a while, such that the gearbox is always cooled instead of periodically when necessary, therefore the engine temperature remains too low. Follow the water pipes, from and to the exchanger, and you will come across the valve.
  12. The bolts are pressed in, you have to burn them red hot with a welding torch, and than tap with a hammer if you do not have hydraulic press. When using a hammer you have to remove the lambda probes, they can easily fail by the vibrations of the hammer.
  13. Defective engine mounts can also cause annoying vibrations and noise, it is worth checking that too.
  14. The fluid line runs along the right-hand side in the roof covering to the rear, then to the middle, in line with the nozzle. The most rear part of the roof covering must be removed to fix the problem, the fluid line jumps off from the connector to the nozzle, usually due to excessive pressure caused by partial or complete blockage of the nozzle. Beware of possible water damage to the electronics inside the lower rear space.
  15. Usually it is the return spring that operates the rod between the inside door handle and the lock mechanism that has been broken. You will have to remove the door lining to restore it.
  16. It may be that the wiper mechanism is stiff, try manually with disassembled wiper motor.
  17. 987 no longer uses double relays for roof control, but two ordinary, one for up and one for down. The same position as i remember correctly.
  18. This is difficult to define without audio clip, but if the vibration noise is barely audible outside the car and well audible inside the car, are the engine mounts suspicious.
  19. In full agreement with "ekstroemj" prices in general are also higher as well.
  20. That's more than double in consumption, in this case the engine should run badly and smoke like an old school diesel. Are you shure there is no leak or the fuel disappeared, by circumstances, in an other vehicle? With M.S. in the background i would pay attention.
  21. It's a Boxster, the wire is located above /rear side of the left rear plastic wheel well.
  22. Is the handle retraction spring, wrapped in black fabric in the pic, not broken?
  23. Follow the wiring of the left pump, under the rear seat. She goes through the car floor, to the far left corner of the car, there is a connection point which will burn in after time and consequently provides too much resistance. If this is the case replace this section.
  24. The pressure cap (filling cap) on the expansion tank is in many cases a source of annoyance due to pressure loss, there are devices on the market to test this but a new one does not cost an arm and a leg and can fixes problems as yours.
