JFP in PA
  1. P0077: Valve lift control driver, above limit value P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2) P0010 "A" Camshaft Position Actuator Circuit (Bank 1) P0020 "A" Camshaft Position Actuator Circuit (Bank 2) P0175 System too Rich (Bank 2) P0171 System too Lean (Bank 1) The rest are misfire codes. Needless to say, this is an odd mix of codes.
  2. What codes were you getting? Codes thrown as the result of a true fault will return if the fault is not corrected.
  3. A rebuild is going to be very expensive, first because you need to have it done by a specialty shop, and second because the engine will need all new liners, which ain't cheap.
  4. The only two proven ways to detect cylinder problems are bore scoping or leak down values. Bore scoping is actually preferred, but not everyone has the tool. Every time we get a PPI for one of these vehicles, we include both tests, particularly if the oil is obviously thick and new. Good luck.
  5. Welcome to RennTech I would do a leak down on the engine. We have seen several of these vehicles that were sold with heavier weight oil in them because one or more cylinders walls were out of round or scored, and had piston slap that they wanted to quiet the engine before trading or selling the car. And long before I would put your oil of choice in it, I would switch the engine to Gibbs DT40 (much better film strength and very high ZDDP levels).
  6. Most every owner want to do what is best for their engines; but unfortunately, sometimes "the view isn't worth the climb". If you are not having issues, and are not ready to drop the engine and tear it apart, this may be one of those times. That said, if you have not yet addressed your IMS, that would be a far better place to spend your time and effort.
  7. Welcome to RennTech Problem with the IMS is its lack of predictability. By the time the engine shows signs that it is dying, it is already too late as the engine is full of finely ground metal and has to come apart. By far, the better approach is to look for signs of failure (metal in the oil or filter, etc.) during a full PPI, and if none is found, plan on doing a proactive IMS retrofit as soon as you buy the car. As mentioned elsewhere, LN Engineering lead the market in the having the proven best IMS retrofit solution's to put your mind and ease.
  8. The PIWIS factory computer is available only by lease, and starts at nearly $20K for the first year. Hardly practical for a one time diagnostic and programing effort. The Durametric system can be had for less than $300 direct from Durametric.
  9. If you are running decent quality oil, do regular maintenance, and have not altered the valve train, your chains should run for a long time. From years of experience, the only time we have seen the chains fail in these engine's was when something else died first, causing the chain to break, not the other way around. For the most part, they seem to run for ever and are one of the least problematic components in the M96 engine.
  10. Welcome to RennTech Year and model are always helpful when answering this type of question.............
  11. We have not been a fan of master link style chains for these cars, primarily as the chain is a bear to replace with the engine in the car (it is unimaginably worse than trying to build a ship in a bottle), and the longevity of the master link assembly itself. Pull the engine and do a proper chain swap, along with any other needed/wanted updates at the same time. Overall, you will probably end up saving time, and you will know the new chain is solid.
  12. Welcome to RennTech It always helps to have the model and year of the car when asking this type of question as the cars vary over time. More than likely, your locking issue is related to the water immersion as the locking and security systems are controlled by a small computer located under the driver's seat on most models. Sometimes this box can be dried out, but not always.
  13. It is a one way valve that is in the end of the cam cover that opens under vacuum. I would also seriously consider running a leak down on the engine that develops pressure; if you have a bad ring in one or more cylinders, or the more common out of round cylinder liners, your problem is more serious. You should not have pressure in the cases while the engine is running.
  14. No, the cams must be locked as well.
  15. Welcome to RennTech Yes.
  16. A good AOS will pull between 3-6 inches of water on a first start of a cold engine, but will then settle down to 5" or less, so anything over 5" on a warm engine is suspect and should be replaced. Secondly, with your crankcase jumping back and forth between vacuum and pressure, your AOS can also be "fluttering", working some of the time, but not all the time. New AOS unit can be bad, we have seen more than a few. Aftermarket (read non factory) AOS units have been a disaster, with many failing within days of being installed. We do not use anything but factory AOS units, and we still check everyone after it is installed because we still see bad ones from time to time.
  17. For future reference, please do not multiple post on the same topic in different threads. It is against forum rules. As point out in the other thread, you have a vacuum leak in your brake booster vacuum line that letting air directly into your intake and causing a lean miss. Fix the leak, you problem will go away.
  18. The answer is yes, it can cause a lean misfire as it is leaking outside air directly into the intake manifold.
  19. Welcome to RennTech I would have to say that the AOS is bad. We check every car that passes through the shop with a digital manometer, and if any one exceeds 5 inches, we recommend replacing the AOS. You also should not be swinging from vacuum to pressure in the crankcase as the low tension piston rings will loose seal. With the engine running, you should always have some level (3-5 inches of water) in the cases. You also have a PCV-like valve at the cam cover end of the long AOS line, which may be momentarily sticking. Not a lot of fun to get at, but not expensive to get a new one.
  20. It is a relatively simple DIY project. Do a search, been written up here several times.
  21. Everything is expensive at the dealer, which is why more people are doing this kind of repair by themselves.
  22. Doesn't matter if it was changed 3 miles ago, it still needs to be tested. A lot of problems like this are traced to the alternator rather than the battery.
  23. Check both the voltage output of your alternator, and if you have the equipment to do so, load test the alternator as well. ABS/PSM faults are common when the available voltage drops too low.
  24. You have far too much time on your hands
  25. You are dead in the water. There is no way to program the car to accept the keys without the factory codes.
