JFP in PA
  1. JFP, I just checked GP2 and GP3 per Bentley Manual. Both are secure and wires look good. I'm running out of ideas... Yes, but did you check them with a multimeter for continuity and resistance? OK, that was easier than I thought. So both circuits involved had a nominal amount of resistance, around 3 ohms. I'm thinking that indicates we have continuity. I'm wondering now if there's a bad connector at the headlamp. The connector at the foglight looks good. I guess I should check for continuity between the headlight connector and fog connector next? Three ohms strikes me as higher than I would expect. Yes, I would also check the headlight connector as well.
  2. JFP, I just checked GP2 and GP3 per Bentley Manual. Both are secure and wires look good. I'm running out of ideas... Yes, but did you check them with a multimeter for continuity and resistance?
  3. Welcome to RennTech. Check the grounds on the light in question.
  4. OK, let's take this one bit at a time. Coolant lines on a 996: Very few AOS failures result in an intermix problem; usually when the AOS fails you get clouds of smoke from oil being sucked into the intake due to excessive vacuum in the system. I replace these things for a living, and every 996 leaving the shop has the coolant version. The 986 has never shown any freeze up tendencies, so no coolant is necessary. Because the AOS connection to intake vacuum is actually behind the throttle body, you will never see any oil in the TB. If you are pulling 10-11 inches of water at the oil fill cap (a good AOS will pull 4-7 inches of water on a cold start, but level off at 5 inches or less vacuum warm), your AOS is toast and should be changed out before you start sucking liquid oil into the intake, which can hydro lock the engine and kill it. Buy a new factory (not aftermarket) AOS and change it before something really stupid happens. That's pretty straight to the point, I appreciate the advice and will get the part on order. I wonder what that plastic tube coming into my intake track just before the TB is if not AOS connection... I have the X-51 kit in case that makes a difference in your response. thx The AOS vacuum connection has to be after the throttle body, or there would be no vacuum. The intake ahead of the throttle body is at atmospheric pressure.
  5. Welcome to RennTech :welcome: P1043 Electric air cleaner flap Possible fault causes - Short circuit to B+/ground or open circuit in the control line - Open circuit of power supply to air cleaner flap solenoid valve - Air cleaner flap solenoid valve faulty - DME control module faulty These look like a problem with the air cleaner/intake flap. All the rest are cylinder misfire codes. I would address the flap issue, clear the codes and see if any of the misfires return.
  6. OK, let's take this one bit at a time. Coolant lines on a 996: Very few AOS failures result in an intermix problem; usually when the AOS fails you get clouds of smoke from oil being sucked into the intake due to excessive vacuum in the system. I replace these things for a living, and every 996 leaving the shop has the coolant version. The 986 has never shown any freeze up tendencies, so no coolant is necessary. Because the AOS connection to intake vacuum is actually behind the throttle body, you will never see any oil in the TB. If you are pulling 10-11 inches of water at the oil fill cap (a good AOS will pull 4-7 inches of water on a cold start, but level off at 5 inches or less vacuum warm), your AOS is toast and should be changed out before you start sucking liquid oil into the intake, which can hydro lock the engine and kill it. Buy a new factory (not aftermarket) AOS and change it before something really stupid happens.
  7. I have no idea what some of those number are, but the Sachs and Luk kits are the same parts units, and the last time I checked, the cheapest pressure plate, disc, and throw out bearing sources were Sunset Porsche or Rock Auto.
  8. Spraying anything onto the cables will result in a stained headliner, the cable tray is not sealed in any way. The cables are lubricated with a high temp petrolatum like product that is designed not to drip when the roof gets hot.
  9. There are only two things that can cause what you are seeing, either the drive motor is on the way out, or the cables are binding. On most models, you can get at the motor without taking the headliner down, the cables require removing the headliner to drop the frame, and is not a fun job.
  10. Like the Tiptronic before it, the PDK can benefit from early service. The clutch oil becomes fouled with solid debris from the wet clutch packs, which the filter removes. And like any filter, the more it filters out, the less it flows.
  11. My car is 6 years old and want to replace the PDK clutch oil. To replace the oil filter - the whole pan should be replaced. Is this pan serves clutches compartment only? Visually it looks to me like it covers the gearbox/cogs part - if it's true than gearbox/cogs oil also has to be changed. So what's the situation with it? The pan in the photo mounts on the bottom of the gear box, but contains the clutch oil filter (gear box is not filtered). Removing the pan does drain the gear box. In order to change your clutch oil, you need access to a PIWIS unit during the process; it is not a simple drain and refill.
  12. Why not just take the bulbs out?
  13. That is with the wing, the lid alone is 99651201101GRV, at around $760.
  14. Board sponsor Sunset Porsche lists it on their parts website: http://www.sunsetporscheparts.com/auto-parts/2001/porsche/911/carrera-trim/3-4l-h6-gas-engine/body-cat/lid-and-components-scat
  15. There is no way of knowing what it is actually for without at least seeing it. Even then, we may never know. How did you end up going this route when an OEM replacement retails for the shipping cost you mentioned?
  16. It does on some cars, but not all. Also not sure if this function is limited to Pro version; would need to check with Durametric to be sure.
  17. Welcome to aftermarket body panels........... :eek:
  18. You should have the dealer check your VIN to see if that recall applies to your car. It may not.
  19. The system is never going to be happy with a seat belt fault, so that problem needs to be addressed and corrected first. Yes, the system needs to be coded to the car, your Durametric should be capable of this on a 997.
  20. Oil looks clean, but you definitely had a coolant intermix, and you still don't know the source of the metal in the oil filter. You are not out of the woods just yet...........
  21. That definitely is a classic intermix. Any photo's of the drained oil?
  22. Welcome to RennTech :welcome: You will find that those are single use barbed fittings which you can only source from Porsche as a rail assembly, or off a wreck. A new one retails at around $390.
  23. Check your crank position sensor. They are well known for acting up when warm and not letting the car start, but not throwing any codes.
